Mikrocontroller.net Forum WinARM / Yagarto / ARM-GCC > TMS470
Posted by Thierry Taing (bunn)
on 26.06.2008 14:36
Hello,
I would like to know if there is somebody, who worked on TMS470r1a256
with WinARM or Eclipse ?
I try to write the different files :
   _ standard TMS470 header file : TMS470r1a256.h
   _ GNU makefile : makefile
   _ startup assembler file : crt.s
   _ GNU linker script file : tms470r1a256-flash.ld
   _ config file for ARM-USB-Tiny : TMS470_OpenOCD-Tiny.cfg
But as I'm a very beginner, I meet many problems :
   _ for the header file and the makefile, I think that it's
approximately ok
(but if somebody could check, it will be better)
   _ for the crt.s, I meet problems with WinARM and Eclipse.
        1. When I build there are error many error about the commands as
"b", "mov", "ldr"... I think that it's because of GNUARM, but I follow
the SPARKFUN's
tutorial(http://www.sparkfun.com/tutorial/ARM/ARM_Cross_Development_with_Eclipse.pdf).
I don't forget to add PATH. I meet this problem for WinARM and Eclipse.
        2. Another problem with crt.s is I don't know how to write it
for TMS470. I don't know what and how I need to initialize.
   _ for the linker script, I don't know what I must write in the MEMORY
section. In the TMS470's datasheet, I don't find adress for Memory
flash, RAM.
I don't understand how does it work.
   _ for the config file, I haven't found any information.
If there are people who can help me, I'd be very happy ! It's some days
I stay at the same point :-(
Thanks a lot !
Best regards
Posted by Damien Hoyen (damien)
on 26.06.2008 14:59
Thierry Taing wrote:
> Hello,
> approximately ok
> the SPARKFUN's
> flash, RAM.
> Thanks a lot !
> Best regards
Hi tierry,
I have never developed on TMS, but i'm using Eclipse, and i was with the
same problem as you as the beginning.
For a part of ASSEMBLARY file (*.s) i could find in example on the web,
the syntax was not digested correctly by GCC (especially comment)...
Particularly when i tried to import a assemblary file from a demo
running under  IAR or Keil.
Simply find a "good" file (written for GCC) or re-write it.
Regards.
Damien
on 26.06.2008 19:10
Hi Damien,
Thanks for your answer.
But the template file *.s that I found is for the lpc2106. It's an
example provided with Eclipse. So I think that it does work.
And it's strange that when I build everywhere there is an assembler
instruction, I've an error message.
After your post, I delete all comments, and there is no change.
If you or another have another idea... :(
Thanks !
Regards.
Thierry
on 27.06.2008 10:58
Attachment: startup.s (4,6 KB)
> Hi Damien,
> Thanks !
> Regards.
> Thierry
Well, here, i attached my startup file use on my project
(target : Arm 9 STR91x.
(I tried to compile it for target ARM7tdmi, seems working)).
You will look the syntax.
Keep me in touch.
Damien
on 27.06.2008 15:52
Attachment: crt0.S (4,3 KB)
Hi Damien,
I can now compile with WinARM. I don't know for Eclipse, because I
uninstalled it.
I can compile now with the assembler file since I've taken a makefile
provided for lpc2106. I modified it a little for TMS470, but I don't
understand..
For the startup file, I used a file for lpc2106 (ARM7tdmi) too, but I
don't understand it all. And I don't know if it is the same
initialization for TMS470.
Could you explain me ?
Another problem is that I would like to use ARM-USB-Tiny to flash the
TMS470
and not use the port com1 as it's configured in the makefile.
You will find different file that I attached.
on 27.06.2008 15:53
Attachment: tms470r1a256-ROM.ld (2,8 KB)
Here the file *.ld
on 27.06.2008 15:53
Attachment: Makefile (11,2 KB)
Makefile
on 27.06.2008 15:56
Thanks a lot for your help !
Thierry
on 27.06.2008 19:27
I forget to ask something more.
When the compile is ok with WinARM and if I have the file .cfg, what do
I have to do to flash the TMS470 with OpenOCD ? What is the process ?
Regards.
Thierry
on 29.06.2008 13:10
Attachment: ARM_USB_Tiny.cfg (1,2 KB)
I wrote the *.cfg file for openocd.
I use ARM-usb-Tiny.
When I execute the command : openocd-ftd2xx -f ARM_USB_Tiny.cfg
I have these error messages :
C:\Program Files\openocd-r717\bin>openocd-ftd2xx -f ARM_USB_Tiny.cfg
Open On-Chip Debugger (2008-06-19 19:00) svn: 717
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk
Info:    options.c:50 configuration_output_handler(): jtag_speed: 3, 3
Info:    options.c:50 configuration_output_handler(): Open On-Chip
Debugger (200
Info:    options.c:50 configuration_output_handler(): Command info not
found
Info:    options.c:50 configuration_output_handler(): using flash keys
0xfffffff
f, 0xffffffff, 0xffffffff, 0xffffffff
Info:    options.c:50 configuration_output_handler(): osc_megahertz=12
Info:    options.c:50 configuration_output_handler(): plldis=0
Error:   jtag.c:1351 jtag_examine_chain(): JTAG communication failure,
check con
nection, JTAG interface, target power etc.
Error:   jtag.c:1556 jtag_init_inner(): trying to validate configured
JTAG chain
 anyway...
Error:   jtag.c:1444 jtag_validate_chain(): Error validating JTAG scan
chain, IR
 mismatch, scan returned 0x00
Error:   jtag.c:1456 jtag_validate_chain(): Error validating JTAG scan
chain, IR
 mismatch, scan returned 0x01
chain, IR
 mismatch, scan returned 0x21
chain, IR
chain, IR
chain, IR
Error:   jtag.c:1565 jtag_init_inner(): Could not validate JTAG chain,
exit
Info:    jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x01010001
(Manufa
cturer: 0x000, Part: 0x1010, Version: 0x0)
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
Info:    jtag.c:1389 jtag_examine_chain(): JTAG device found: 0x81010001
(Manufa
cturer: 0x000, Part: 0x1010, Version: 0x8)
Error:   jtag.c:1399 jtag_examine_chain(): number of discovered devices
in JTAG
chain (20) doesn't match configuration (1)
Error:   jtag.c:1400 jtag_examine_chain(): check the config file and
ensure prop
er JTAG communication (connections, speed, ...)
JTAG chain
 anyway...
chain, IR
chain, IR
chain, IR
chain, IR
chain, IR
chain, IR
exit
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
(Manufa
in JTAG
ensure prop
JTAG chain
 anyway...
chain, IR
chain, IR
chain, IR
chain, IR
chain, IR
chain, IR
exit
Is there any body could help me ?
Thanks in advance,
Best regards
Thierry
on 08.07.2008 22:04
Hi everybody,
I need some help !!!
I have the different files *.bin, *.cfg, *.script to flash the TMS470
with OpenOCD, but when I launch the command, I get error message.
1. I get the following message : "sector was locked", "TMS470 could not
erase flash sector".
2. And another error message is : arm7_9_common.c:581
arm7_9execute_sys_speed() : timeout waiting for SYSCOMP & DBGACK, last
DBG_STATUS :10
For the first error message, I try to solve the issue in different ways
1. I used the commands in *.cfg file : flash protect in order to disable
the protection for erase/writing sectors, flash erase_sector. But it
doesn't work. These commands are not found.
2. Then I see in the TMS470 datasheet. there are some registers to
configure to choose the location of the memory flash and to enable
erase/write sectors. I wanted to configure the different registers in
the assembler file *.s, but I meet some issues when I compile. And I'm
not sure, it is there that I must do that.
I wrote this in the _start in the assembler file :
.set GLBCTRL, 0xffffffdc
.set MFBALR0, 0xfffffe04
.set MFBAHR0, 0xfffffe00
// Memory Fine Base Address High Register 0
// ldr r0,=MFBAHR0 //
// mov r1,#0xfffffe00 //error
// and r0,r0,#0xffff0000 //error
// str r0,[r1] //
// Memory Fine Base Address Low Register 0
// ldr r0,=MFBALR0 //
// mov r1,#0xfffffe04 //error
// and r0,r0,#0xffff0384 //error
// str r0,[r1] //
ldr r0,=GLBCTRL
mov r1,#0xffffffdc
orr r0,r0,#0x00000010
str r0,[r1] // GLBCTRL4=1
For the second error message, I don't understand.
If there is somebody who could help me, I will be very happy !
Thanks in advance.
Best regards
Thierry
