Hi, I'm using WinARM (Version 20070505) and sometime make crashes. It always happen right after the "Size After" print out. The make command doesn't have any parameters, it is simply "make". The makefile is a minor modified standard winarm makefile. I've added my own files and changed a bit in the include path but besides that nothing. I use newlib and stdc++. The build doesn't fail, a hex file is genereted. From mu console: Creating Symbol Table: AutoPilot.sym arm-elf-nm -n AutoPilot.elf > AutoPilot.sym Size after: abnormal program termination zsh: fork failed: no child processes make: *** [sizeafter] Error 1 It doesn't happen every time and it seams that there isn't a pattern in the crashes. I can rerun the make command and get a successful build. Anybody have a solution/hint/advice/...? /alsig
on 09.06.2008 16:36
on 09.06.2008 16:55
BTW: I just discovered that it also sometimes happens at the "Size before" print out... /alsig
