I'm trying to compile an MP3 decoder (Helix) with CodeSourcery for ARM Cortex-M3, and can't shake this error: arm-none-eabi/lib/thumb2\libc.a(lib_a-sbrkr.o): In function `_sbrk_r': sbrkr.c:(.text+0xc): undefined reference to `_sbrk' collect2: ld returned 1 exit status I've spent hours searching the Internet for info on the error, and hours fiddling with things trying to fix it. I can compile a simple LED blink program. I believe this error is related to "syscall", but I don't understand what I need to do to fix it. Wouldn't this be handled by the compiler? If not, would it be possible that the micro vendor (Luminary) provides a library with the missing piece? I'd gladly read a small book to resolve this problem, but don't know what or where to look for it.
on 06.06.2008 03:23
on 06.06.2008 16:18
Jerry Milner wrote: > I'm trying to compile an MP3 decoder (Helix) with CodeSourcery for ARM > Cortex-M3, and can't shake this error: > > arm-none-eabi/lib/thumb2\libc.a(lib_a-sbrkr.o): In function `_sbrk_r': > sbrkr.c:(.text+0xc): undefined reference to `_sbrk' > collect2: ld returned 1 exit status > > > I've spent hours searching the Internet for info on the error, and hours > fiddling with things trying to fix it. I can compile a simple LED blink > program. I believe this error is related to "syscall", but I don't > understand what I need to do to fix it. The fix is to provide the requested function _sbrk. > Wouldn't this be handled by the compiler? No, it's not related to the compiler but to the libc (=newlib). I expect the MP3-decoder source from the Helix community uses malloc. It seem that in the CS newlib configuration malloc calls the reentrant version of _sbrk_r which is already in libc.a and _sbrk_r calls _sbrk which has to be provided. > If not, would it be possible that the micro vendor (Luminary) > provides a library with the missing piece? Sure, they could add this to the driver-library. But it's not that difficult to add it yourself. > I'd gladly read a small book to resolve this problem, but don't know > what or where to look for it. (1) I expect you are using the linker-script form the Luminary Driver-Library (standalone.ld). Modify this script a little bit: [...] .bss : { _bss = .; *(.bss*) *(COMMON) _ebss = .; . = ALIGN (8); _end = .; } > SRAM PROVIDE(__HEAP_START = _end ); [...] (2) create a file syscalls.c and add the following code: /* based on a example-code from Keil for CS G++ */ /* for caddr_t (typedef char * caddr_t;) */ #include <sys/types.h> extern int __HEAP_START; caddr_t _sbrk ( int incr ) { static unsigned char *heap = NULL; unsigned char *prev_heap; if (heap == NULL) { heap = (unsigned char *)&__HEAP_START; } prev_heap = heap; /* check removed to show basic approach */ heap += incr; return (caddr_t) prev_heap; } (3) make sure the file is compiled and the object-code from it gets linked This should get you started (not tested here). You can add additional "out of heap-space" checks later if needed. Hope this helps. EDIT: added include
on 07.06.2008 01:52
Martin Thomas wrote: > This should get you started (not tested here). You can add additional > "out of heap-space" checks later if needed. > > Hope this helps. > > EDIT: added include Thank you! I initially tried to get it to compile, but that was without the include. I didn't spend much extra time on it until now. It's compiling....now I have a place to start.
