Hello, MCU: at91sam7s64 toolchain: Yagarto(gcc 4.2.2) 1) I'm studying the flash handling reference source code by Atmel and found that in most functions doing flash operations (erase, write, lock) this code snippet exists: //* set the Flash controller base address AT91PS_MC ptMC = AT91C_BASE_MC; ... //* Write the Set Lock Bit command ptMC->MC_FCR = AT91C_MC_CORRECT_KEY | AT91C_MC_FCMD_LOCK | (AT91C_MC_PAGEN & (Flash_Lock_Page << 8) ) ; Why can't we simply do: AT91C_BASE_MC->MC_FCR = AT91C_MC_CORRECT_KEY | AT91C_MC_FCMD_LOCK | (AT91C_MC_PAGEN & (Flash_Lock_Page << 8) ) ; Is there any special point in declaring that extra pointer and address to the fields of structure in such a way, or it's simply a coding style? 2) am I right that read access to the flash is permitted when Lock/Unlock command is performed? So __ramfunc function attribute is not needed in this case? 3) I don't quite understand how FMCN field of MC_FMR register is calculated. In Atmel examples: AT91C_BASE_MC->MC_FMR = ((AT91C_MC_FMCN) & (72 << 16)) | AT91C_MC_FWS_1FWS; Well, I understand how they choose wait state, but what does 72 mean, provided that master clock is 47923200 Hz? Moreover, for lock bits handling they program this field in another way: AT91C_BASE_MC->MC_FMR = ((AT91C_MC_FMCN) & (48 << 16)) | AT91C_MC_FWS_1FWS Why is it so? Why can't we use the same amoount of cycles for both operations? Thanks.
on 31.05.2008 15:46
on 02.06.2008 15:05
Roman Mashak wrote: > 2) am I right that read access to the flash is permitted when > Lock/Unlock > command is performed? So __ramfunc function attribute is not needed in > this case? I figured out with this point, but others are still unclear. especially with FMCN calculations. Datasheet is not very eloquent about it. I hope somebody can shed some light on it.
on 02.06.2008 16:40
Roman Mashak wrote: > Roman Mashak wrote: >> 2) am I right that read access to the flash is permitted when >> Lock/Unlock >> command is performed? So __ramfunc function attribute is not needed in >> this case? > > I figured out with this point, but others are still unclear. especially > with FMCN calculations. Datasheet is not very eloquent about it. I hope > somebody can shed some light on it. I honestly don't remember what all the other things you said actually mean/if they are required, but I know for our project we just left them the same and everything worked out fine :) And yea, that ramfunc is definitely needed :)
