I tried to port some code from the gnuarm.com toolchain to the codesourcery one. The code compiles ok, and I can program my LPC2148 chip, but the timer/interrupt code doesn't seem to be working. I have a LPC2148 Olimex development board I have been trying to learn how to program using linux/openocd. I got the timer demo from "Accessing ARM-Controllers with OpenOCD" http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/openocd_intro/index.html working with gnuarm (from gnuarm.com gcc v3.4.3 binary). I changed the programs in the makefile from arm-elf-* to arm-none-linux-gnueabi-* to use the codesourcery toolchain. It compiles ok and I can program the chip, but the pins don't change value. (I have LEDs hooked up to a couple of the output pins). If I don't use the timer, and just use a counter, the code works ok. ie: int main (void) { int flip; DWORD lasttime, now; int counter; /************ The main Function is an endless loop ************/ /* The timer routine is tested on the Keil MCB214x board */ // ...and on an Keil MCB2130 by Martin Thomas IODIR1 = 0x00FF0000; /* P1.16..23 defined as Outputs */ IOCLR1 = 0x00FF0000; /* turn off all the LEDs */ IOSET1 = 0x00AA0000; /* turn on some LEDs to indicate start */ //init_VIC(); //init_timer(); //enable_timer( 0 ); flip = 0; lasttime = timer_counter; counter = 0; while (1) { /* Loop forever */ //now = timer_counter; //if ( (DWORD)(now-lasttime) > 0x100 ) { // lasttime = now; if( ++counter > 10000000 ) { counter = 0; if (flip == 0) { IOSET1 = 0x000F0000; /* turn off P1.20~23 */ IOCLR1 = 0x00F00000; /* turn on P1.16~19 */ flip = 1; } else { IOSET1 = 0x00F00000; /* turn on P1.20~23 */ IOCLR1 = 0x000F0000; /* turn off P1.16~19 */ flip = 0; } } } return 0; } So is there something with interrupts or the timer which is different in gnuarm vs codesourcery? Or am I missing something else? Side note: in the latest svn version of openOCD, the flash erase_sector and write_bank commands worked for me. Thanks Martin! =)
on 26.05.2008 07:34
on 26.05.2008 10:02
Update: There seems to be a problem with calling the init_VIC() function. The function isn't getting called properly, or is not linked correctly. Code in the init_VIC() function isn't being called, and the program doesn't return back to the main() function after trying to call init_VIC();
on 26.05.2008 23:39
Whoops... I was using the wrong Codesourcery package. I downloaded the EABI package instead of the Linux/GNU package and changed the make file to use the arm-none-eabi-* commands, and it works now. :D
