/***********************************************************************/ /* */ /* FLASH.ld: Linker Script File */ /* */ /***********************************************************************/ ENTRY(_boot) STACK_SIZE = 0x400; /* Memory Definitions */ MEMORY { FLASH : ORIGIN = 0x00000000, LENGTH = 256K } /* Section Definitions */ SECTIONS { /* first section is .text which is used for code */ .text : { *crt0.o (.text) /* Startup code */ *(.text) /* remaining code */ *(.rodata) /* read-only data (constants) */ *(.rodata*) *(.glue_7) *(.glue_7t) } > FLASH . = ALIGN(4); _etext = . ; PROVIDE (etext = .); /* .data section which is used for initialized data */ .data : { _data = .; *(.data) } > FLASH . = ALIGN(4); _edata = . ; PROVIDE (edata = .); /* .bss section which is used for uninitialized data */ .bss (NOLOAD) : { __bss_start = . ; __bss_start__ = . ; *(.bss) *(COMMON) . = ALIGN(4); } > FLASH . = ALIGN(4); __bss_end__ = . ; PROVIDE (__bss_end = .); .stack ALIGN(256) : { . += STACK_SIZE; PROVIDE (_stack = .); } > FLASH _end = . ; PROVIDE (end = .); /* Stabs debugging sections. */ .stab 0 : { *(.stab) } .stabstr 0 : { *(.stabstr) } .stab.excl 0 : { *(.stab.excl) } .stab.exclstr 0 : { *(.stab.exclstr) } .stab.index 0 : { *(.stab.index) } .stab.indexstr 0 : { *(.stab.indexstr) } .comment 0 : { *(.comment) } /* DWARF debug sections. Symbols in the DWARF debugging sections are relative to the beginning of the section so we begin them at 0. */ /* DWARF 1 */ .debug 0 : { *(.debug) } .line 0 : { *(.line) } /* GNU DWARF 1 extensions */ .debug_srcinfo 0 : { *(.debug_srcinfo) } .debug_sfnames 0 : { *(.debug_sfnames) } /* DWARF 1.1 and DWARF 2 */ .debug_aranges 0 : { *(.debug_aranges) } .debug_pubnames 0 : { *(.debug_pubnames) } /* DWARF 2 */ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) } .debug_abbrev 0 : { *(.debug_abbrev) } .debug_line 0 : { *(.debug_line) } .debug_frame 0 : { *(.debug_frame) } .debug_str 0 : { *(.debug_str) } .debug_loc 0 : { *(.debug_loc) } .debug_macinfo 0 : { *(.debug_macinfo) } /* SGI/MIPS DWARF 2 extensions */ .debug_weaknames 0 : { *(.debug_weaknames) } .debug_funcnames 0 : { *(.debug_funcnames) } .debug_typenames 0 : { *(.debug_typenames) } .debug_varnames 0 : { *(.debug_varnames) } }
