/* Default linker script for STR91xFx44 Copyright RAISONANCE S.A.S. 2007 */ /* higher address of the user mode stack */ _estack = 0x4018000; /* include the common STRxxx sub-script */ /* Common part of the linker scripts for STR91x devices Copyright RAISONANCE 2006 You can use, modify and distribute thisfile freely, but without any waranty. */ /* Registers mapping */ EXTMEM_BASE = 0x30000000 ; FMI_BASE = 0x54000000 ; APB0_BASE = 0x58000000 ; APB1_BASE = 0x5C000000 ; USB_BASE = 0x70000000 ; EMI_BASE = 0x74000000 ; DMA_BASE = 0x78000000 ; VIC0_BASE = 0xFFFFF000 ; VIC1_BASE = 0xFC000000 ; PROVIDE( _DMA = (DMA_BASE) ); PROVIDE( _EMI = (EMI_BASE) ); PROVIDE( _VIC0 = (VIC0_BASE) ); PROVIDE( VIC0VECT = (VIC0_BASE + 0x0030) ); PROVIDE( _VIC1 = (VIC1_BASE) ); PROVIDE( VIC1VECT = (VIC1_BASE + 0x0030) ); PROVIDE( _USB = (USB_BASE) ); PROVIDE( _AHBAPB0 = (APB0_BASE) ); PROVIDE( _WIU = (APB0_BASE + 0x1000) ); PROVIDE( _TIM0 = (APB0_BASE + 0x2000) ); PROVIDE( _TIM1 = (APB0_BASE + 0x3000) ); PROVIDE( _TIM2 = (APB0_BASE + 0x4000) ); PROVIDE( _TIM3 = (APB0_BASE + 0x5000) ); PROVIDE( _GPIO0 = (APB0_BASE + 0x6000) ); PROVIDE( _GPIO1 = (APB0_BASE + 0x7000) ); PROVIDE( _GPIO2 = (APB0_BASE + 0x8000) ); PROVIDE( _GPIO3 = (APB0_BASE + 0x9000) ); PROVIDE( _GPIO4 = (APB0_BASE + 0xA000) ); PROVIDE( _GPIO5 = (APB0_BASE + 0xB000) ); PROVIDE( _GPIO6 = (APB0_BASE + 0xC000) ); PROVIDE( _GPIO7 = (APB0_BASE + 0xD000) ); PROVIDE( _GPIO8 = (APB0_BASE + 0xE000) ); PROVIDE( _GPIO9 = (APB0_BASE + 0xF000) ); PROVIDE( _AHBAPB1 = (APB1_BASE) ); PROVIDE( _RTC = (APB1_BASE + 0x1000) ); PROVIDE( _SCU = (APB1_BASE + 0x2000) ); PROVIDE( _MC = (APB1_BASE + 0x3000) ); PROVIDE( _UART0 = (APB1_BASE + 0x4000) ); PROVIDE( _UART1 = (APB1_BASE + 0x5000) ); PROVIDE( _UART2 = (APB1_BASE + 0x6000) ); PROVIDE( _SPI0 = (APB1_BASE + 0x7000) ); PROVIDE( _SPI1 = (APB1_BASE + 0x8000) ); PROVIDE( _CAN = (APB1_BASE + 0x9000) ); PROVIDE( _ADC = (APB1_BASE + 0xA000) ); PROVIDE( _WDG = (APB1_BASE + 0xB000) ); PROVIDE( _I2C0 = (APB1_BASE + 0xC000) ); PROVIDE( _I2C1 = (APB1_BASE + 0xD000) ); /* default stack sizes. From lnkarm_flash.xcl (IAR config file) -D_CSTACK_SIZE=0x1000 -D_SVC_STACK_SIZE=0x100 -D_IRQ_STACK_SIZE=0x400 -D_FIQ_STACK_SIZE=0x40 -D_ABT_STACK_SIZE=0x40 -D_UND_STACK_SIZE=0x40 -D_HEAP_SIZE=0x400 These are used by the startup in order to allocate stacks for the different modes. */ __USR_Stack_Size = 4096 ; __SVC_Stack_Size = 256 ; __IRQ_Stack_Size = 1024 ; __FIQ_Stack_Size = 64 ; __ABT_Stack_Size = 64 ; __UND_Stack_Size = 64 ; __SVC_Stack_Init = _estack ; __IRQ_Stack_Init = __SVC_Stack_Init - __SVC_Stack_Size ; __USR_Stack_Init = __IRQ_Stack_Init - __IRQ_Stack_Size ; __FIQ_Stack_Init = __USR_Stack_Init - __USR_Stack_Size ; __ABT_Stack_Init = __FIQ_Stack_Init - __FIQ_Stack_Size ; __UND_Stack_Init = __ABT_Stack_Init - __ABT_Stack_Size ; /*"PROVIDE" allows to easily override these values from an object file or the commmand line.*/ PROVIDE ( _SVC_Stack_Init = __SVC_Stack_Init ) ; PROVIDE ( _IRQ_Stack_Init = __IRQ_Stack_Init ) ; PROVIDE ( _USR_Stack_Init = __USR_Stack_Init ) ; PROVIDE ( _FIQ_Stack_Init = __FIQ_Stack_Init ) ; PROVIDE ( _ABT_Stack_Init = __ABT_Stack_Init ) ; PROVIDE ( _UND_Stack_Init = __UND_Stack_Init ) ; /* the user mode stack is an exception because we want it at the end of the RAM. therefore, we just check against a minimum. The value below is the minimum memory required for ALL THE STACKS. There will be a link error if there is not this amount of RAM free at the end. */ _Minimum_Stack_Size = 0xC00 ; /* default ISR addresses. The startup needs these addresses defined from another object file. In case they are not, these PROVIDEs redirect them to the Reset. _start must be defined, usually in the startup. */ PROVIDE( Undefined_Handler = _start ); PROVIDE( SWI_Handler = _start ); PROVIDE( Prefetch_Handler = _start ); PROVIDE( Abort_Handler = _start ); PROVIDE( FIQ_Handler = _start ); PROVIDE( T0TIMI_IRQHandler = _start ); PROVIDE( FLASH_IRQHandler = _start ); PROVIDE( RCCU_IRQHandler = _start ); PROVIDE( RTC_IRQHandler = _start ); PROVIDE( WDG_IRQHandler = _start ); PROVIDE( XTI_IRQHandler = _start ); PROVIDE( USBHP_IRQHandler = _start ); PROVIDE( I2C0ITERR_IRQHandler = _start ); PROVIDE( I2C1ITERR_IRQHandler = _start ); PROVIDE( UART0_IRQHandler = _start ); PROVIDE( UART1_IRQHandler = _start ); PROVIDE( UART2_IRQHandler = _start ); PROVIDE( UART3_IRQHandler = _start ); PROVIDE( BSPI0_IRQHandler = _start ); PROVIDE( BSPI1_IRQHandler = _start ); PROVIDE( I2C0_IRQHandler = _start ); PROVIDE( I2C1_IRQHandler = _start ); PROVIDE( CAN_IRQHandler = _start ); PROVIDE( ADC12_IRQHandler = _start ); PROVIDE( T1TIMI_IRQHandler = _start ); PROVIDE( T2TIMI_IRQHandler = _start ); PROVIDE( T3TIMI_IRQHandler = _start ); PROVIDE( HDLC_IRQHandler = _start ); PROVIDE( USBLP_IRQHandler = _start ); PROVIDE( T0TOI_IRQHandler = _start ); PROVIDE( T0OC1_IRQHandler = _start ); PROVIDE( T0OC2_IRQHandler = _start ); /*********** BEGIN SUBSCRIPT ************/ /* Linker subscript for STR91xFxxx definitions Copyright RAISONANCE 2006 You can use, modify and distribute this file freely, but without any warranty. */ /* Memory Spaces Definitions */ MEMORY { FLASH (rx) : ORIGIN = 0, LENGTH = 512K FLASHB1 (rx) : ORIGIN = 0x80000, LENGTH = 32K EXTMEMB0 (rx) : ORIGIN = 0x30000000, LENGTH = 64M EXTMEMB1 (rx) : ORIGIN = 0x34000000, LENGTH = 64M EXTMEMB2 (rx) : ORIGIN = 0x38000000, LENGTH = 64M EXTMEMB3 (rx) : ORIGIN = 0x3C000000, LENGTH = 64M RAM (xrw) : ORIGIN = 0x4000000, LENGTH = 96K } /* nbb = NON BOOT BANK */ PROVIDE ( _bb_size = 0x4 ) ; PROVIDE ( _nbb_size = 0x3 ) ; PROVIDE ( _nbb_addr = 0x80000 ) ; /************ END SUBSCRIPT *************/ /* include the sections management sub-script for FLASH mode */ /* Common part of the linker scripts for STR71x devices in FLASH mode (that is, the FLASH is seen at 0) Copyright RAISONANCE 2005 You can use, modify and distribute this file freely, but without any warranty. */ /* Sections Definitions */ SECTIONS { /* for some STRx devices, the beginning of the startup code is stored in the .flashtext section, which goes to FLASH */ .flashtext : { . = ALIGN(4); *startup/91x_init.o (.flashtext) /* startup code (ARM vectors and reset handler) */ . = ALIGN(4); } >FLASH /* the program code is stored in the .text section, which goes to Flash */ .text : { . = ALIGN(4); *(.text) /* remaining code */ *(.text.*) /* remaining code */ *(.rodata) /* read-only data (constants) */ *(.rodata*) *(.glue_7) *(.glue_7t) . = ALIGN(4); _etext = .; /* This is used by the startup in order to initialize the .data secion */ _sidata = _etext; } >FLASH /* This is the initialized data section The program executes knowing that the data is in the RAM but the loader puts the initial values in the FLASH (inidata). It is one task of the startup to copy the initial values from FLASH to RAM. */ .data : AT ( _sidata ) { . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _sdata = . ; *(.data) *(.data.*) . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _edata = . ; } >RAM /* This is the uninitialized data section */ .bss : { . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _sbss = .; *(.bss) *(COMMON) . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _ebss = . ; } >RAM PROVIDE ( end = _ebss ); PROVIDE ( _end = _ebss ); /* This is the user stack section This is just to check that there is enough RAM left for the User mode stack It should generate an error if it's full. */ ._usrstack : { . = ALIGN(4); _susrstack = . ; . = . + _Minimum_Stack_Size ; . = ALIGN(4); _eusrstack = . ; } >RAM /* this is the FLASH Bank1 */ /* the C or assembly source must explicitly place the code or data there using the "section" attribute */ .b1text : { *(.b1text) /* remaining code */ *(.b1rodata) /* read-only data (constants) */ *(.b1rodata*) } >FLASHB1 /* this is the EXTMEM */ /* the C or assembly source must explicitly place the code or data there using the "section" attribute */ /* EXTMEM Bank0 */ .eb0text : { *(.eb0text) /* remaining code */ *(.eb0rodata) /* read-only data (constants) */ *(.eb0rodata*) } >EXTMEMB0 /* EXTMEM Bank1 */ .eb1text : { *(.eb1text) /* remaining code */ *(.eb1rodata) /* read-only data (constants) */ *(.eb1rodata*) } >EXTMEMB1 /* EXTMEM Bank2 */ .eb2text : { *(.eb2text) /* remaining code */ *(.eb2rodata) /* read-only data (constants) */ *(.eb2rodata*) } >EXTMEMB2 /* EXTMEM Bank0 */ .eb3text : { *(.eb3text) /* remaining code */ *(.eb3rodata) /* read-only data (constants) */ *(.eb3rodata*) } >EXTMEMB3 __exidx_start = .; __exidx_end = .; /* after that it's only debugging information. */ /* remove the debugging information from the standard libraries */ /DISCARD/ : { libc.a ( * ) libm.a ( * ) libgcc.a ( * ) } /* Stabs debugging sections. */ .stab 0 : { *(.stab) } .stabstr 0 : { *(.stabstr) } .stab.excl 0 : { *(.stab.excl) } .stab.exclstr 0 : { *(.stab.exclstr) } .stab.index 0 : { *(.stab.index) } .stab.indexstr 0 : { *(.stab.indexstr) } .comment 0 : { *(.comment) } /* DWARF debug sections. Symbols in the DWARF debugging sections are relative to the beginning of the section so we begin them at 0. */ /* DWARF 1 */ .debug 0 : { *(.debug) } .line 0 : { *(.line) } /* GNU DWARF 1 extensions */ .debug_srcinfo 0 : { *(.debug_srcinfo) } .debug_sfnames 0 : { *(.debug_sfnames) } /* DWARF 1.1 and DWARF 2 */ .debug_aranges 0 : { *(.debug_aranges) } .debug_pubnames 0 : { *(.debug_pubnames) } /* DWARF 2 */ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) } .debug_abbrev 0 : { *(.debug_abbrev) } .debug_line 0 : { *(.debug_line) } .debug_frame 0 : { *(.debug_frame) } .debug_str 0 : { *(.debug_str) } .debug_loc 0 : { *(.debug_loc) } .debug_macinfo 0 : { *(.debug_macinfo) } /* SGI/MIPS DWARF 2 extensions */ .debug_weaknames 0 : { *(.debug_weaknames) } .debug_funcnames 0 : { *(.debug_funcnames) } .debug_typenames 0 : { *(.debug_typenames) } .debug_varnames 0 : { *(.debug_varnames) } }
